Batería adicional inteligente EcoFlow DELTA Pro
EcoFlow ES
1249 €
Garantía de precio de 30 días
Envío rápido y gratuito
Protección de garantía
Soporte de por vida
🎄 Rebajas de Navidad | ¡Hasta un 60 % de descuento
Precio regular 1249 €
Precio de venta 1249 € Precio regular 1799 €
Rebaja Agotado
Ahorra hasta 550 €
Hasta en deducciones en efectivo. Registro.
Impuestos incluidos.
• Batería adicional de 3600 Wh para DELTA Pro
• Capacidad ampliable hasta 10,6 kWh con 2 baterías adicionales
• Cómoda recarga con DELTA Pro: Carga de CA, mediante energía solar, generador inteligente Smart Generator, de vehículo y vehículo eléctrico
• Batería LFP de larga duración
Más información
Puede que también necesites
1249 € 1799 € -550 €
Texto previo al pedido
Make it a triple.
Double or triple the capacity of your DELTA Pro to 7.2kWh or 10.8kWh. That'll give you days of power for your essential appliances.
Charge anytime, anywhere.
DELTA Pro's Smart Extra Battery benefits from all the charging methods DELTA Pro has, including 6500W MultiCharge. That means you can charge anytime, anywhere as long as your extra battery is connected to DELTA Pro. Once connected, they'll charge/discharge in unison, keeping the battery percent level across both units.
Ready for any emergency.
When the going gets tough and you're out of charge options, get a 1800W DC fast charge with EcoFlow Smart Generator (sold separately). Just plug the generator directly into your extra battery via the port on the back. This works even when disconnected from your DELTA Pro.
Stay informed.
The Smart Extra Battery sports a bright LCD screen on the front of the unit giving you all the info you need. Output, input, remaining charge and time remaining. It's all there. Need on the go info? The EcoFlow app can tell you all that & a whole lot more.
Contenido
1.DELTA Pro Smart Extra Battery 2.DELTA Pro Extra Battery Cable 3.Handle Cover 4.User Manual
Preguntas frecuentes
For each DELTA Pro unit, you can link an extra two batteries, bringing you up to 10.8kWh of capacity.
DELTA Pro's Smart Extra Battery can be monitored from the EcoFlow app, allowing you to monitor & control your batteries from afar.
Yes, you can when using the Smart Generator as part of your ecosystem. For other charging methods, you should connect your Smart Extra Battery to the DELTA Pro unit first.
The charge speed varies depending on your chosen charge method. But in short, it charges fast. The fastest way to charge is by utilizing MultiCharge to reach a 6500W charge speed. With that, you can charge both your DELTA Pro and the extra battery in <2 hours. And via a standard AC wall outlet, you can expect a full charge in 2.7 hours assuming your DELTA Pro unit is fully charged.
Especificaciones
Model Name
Capacidad
3600 Wh
Química de la batería
Battery Cycle Life
6500 ciclos al 50 % de la capacidad, 3500 ciclos al 80 % de la capacidad
Shelf Life
1 year (after a full charge)
Dimensiones
25 x 11.2 x 16.4 in / 63.5 x 28.5 x 41.6 cm
Peso
Approx. 84lbs / 38kg
Especificaciones
MPPT
2
Potencia de entrada FV
600 W x 2
Tensión de entrada
16~60 VCC
Salida de CA / Conexión a la red
800 W
Potencia de salida de CA
3,48 А
Temperatura de funcionamiento
-40 °C~65 °C
Conexión
Wi-Fi/Bluetooth
Grado de protección contra entradade agua
IP67
Peso neto
3,2 kg
Dimensiones
252 mm x 180 mm x 35 mm
Ruido acústico
<20 dB
Garantía
10 años
